Hi guys,
I am trying to implement the following code found in arduino' s website without any luck. Does the pin 4 actually represent pin 4 of the ardupilot output? please let me know. Just bought it yesterday and I cannot wait to start programming it.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
void setup()
myservo.attach(4); // attaches the servo on pin 9 to the servo object
void loop()
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
Thank you guys.
For some tech reasons you need to use the Arduino compiler also available there.
Regards, Soren
