Hi guys,
I am trying to implement the following code found in arduino' s website without any luck. Does the pin 4 actually represent pin 4 of the ardupilot output? please let me know. Just bought it yesterday and I cannot wait to start programming it.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
void setup()
myservo.attach(4); // attaches the servo on pin 9 to the servo object
void loop()
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
Thank you guys.
No, you will need to look at the schematic for APM2.5+ see http://store.3drobotics.com/products/apm-2-5-kit for the 'Eagle' files which has the schematic. You can download Eagle to view it in (google it).
Output PWM 4 = PG5 on the 2560 chip. To know what PG5 is google for
ATmega2560 datasheet it's on ATMEL site for free.
