ArduPilot 2_7_1 Test Program for IMU does not work
Hi, I am a novice of Ardu Project.  I got a MediaTek GPS, a ArduIMU+ with  ArduPilot(red). My GPS and IMU work well in miniGPS Test and ArduIMUTest respectively.  But I failed to do Test Program 6.
Test 6
But after removing the IMU, it shows:
Besides, how can I connect my FTDI cable to ArduPilot or the shield if I connect my components as instruction:
There is no room for the FTDI cable.  What did I set wrong?  Pls enlighten me. Million thanks.
Tags: ArduIMU, GPS, MediaTak
You need to remove the Xbee to connect your FTDI.
Hook the GPS directly to your ardupilot and set it up that way. Your GPS is not configured properly and I am not confidant in the Mediatek implementation on the IMU. (I didn't build it.) The MTK GPS needs to receive commands to put it into Binary from NMEA (Nasty Strings).
Once you get the Mediatek talking binary by connecting it to Ardupilot, you can reconnect the IMU.
ArduPilot 2_7_1 Test Program 6 for IMU wihout connecting IMU, then serial monitor shows:
After connecting IMU:
Please upload your AP_Config.h file. It looks like you've got a setting wrong.
Here are my AP_Config.h settings:
#define DEBUG_SUBSYSTEM 6
#define POSITION_1 MANUAL // the default, don't bother changing.
#define POSITION_2 STABILIZE
#define POSITION_3 FLY_BY_WIRE_A
#define SHIELD_VERSION 1
#define AIRSPEED_SENSOR 1
#define GPS_PROTOCOL 3
#define GCS_PROTOCOL -1
Here are my Arud IMU settings:
#define BOARD_VERSION 2 // 1 For V1 and 2 for V2
#define GPS_PROTOCOL 4 // 1 - NMEA, 2 - EM406, 3 - Ublox, 4 -- MediaTek
#define ENABLE_AIR_START 0 // 1 if using airstart/groundstart signaling, 0 if not
#define GROUNDSTART_PIN 8
#define SPEEDFILT 2 // >1 use min speed filter for yaw drift cancellation, 0=do not use speed filter
#define PRINT_DEBUG 0 //Will print Debug messages
#define OUTPUTMODE 1
#define PRINT_DCM 1 //Will print the whole direction cosine matrix
#define PRINT_ANALOGS 0 //Will print the analog raw data
#define PRINT_EULER 0 //Will print the Euler angles Roll, Pitch and Yaw
#define PRINT_GPS 0 //Will print GPS data
#define PRINT_BINARY 1 //Will print binary message and suppress ASCII messages (above)
#define PERFORMANCE_REPORTING 1 //Will include performance reports in the binary output ~ 1/2 min
#define USE_MAGNETOMETER 0
#define USE_BAROMETER 0
#define ALT_MIX 50
Please advise me any incorrect settings? Thanks.
You have you IMU connected to the ArduPilot with the GPS cable, I dont think this is correct.
As per the doco use the GPS cable to connect the GPS to the IMU. Use jumper wires to connect the IMU to the ArduPilot.
There are some great pictures in http://code.google.com/p/ardupilot/wiki/ArduIMU
Indeed. Tommy, if you don't connect the gear exactly as directed in the manual, it won't work.
Many thanks Simon. If I connect the ArduIMU and Ardupilot as the pictures in your link, there is no other connector for the conection of the FTDI cable as AP RXi or shield IN Pin are connecting ArduIMU Tx pin. How can I connect FTDI cable to monitor the Serial output?
I dont think you can with out an Xbee.
I use the Xbees with my IMU and it works very well!
Many thanks Simon and Chris, I make it!
But it is quite misleading in the manual...... I always thought connecting the FTDI cable directly to ArduPilot for getting the test results.
Glad it's working, Tommy. Can you point out the page in the manual that was misleading, so I can improve it?
Hi Chris,
All the pags of Test Program show that the outputs are from the Arduino Serial Monitor. So I thought the FTDI cable should connect to the Ardupilot for getting the results of Test 6. In fact, I got good results of Test 1 to Test 5 and Test 7 in this way so I thought how to connect both FTDI cable and IMU to Ardupilot at the smae time.
http://code.google.com/p/ardupilot/wiki/IMU
http://code.google.com/p/ardupilot/wiki/GPSInput
Hi Tommy,
The reason for this (I think) is the ArduPilot only has one serial port. The one serial is used for the two devices. One input and one Output.
The Rx is used for the IMU and the Tx is used for the Xbee. There is only one-way communication for each device.
Therefore there is no room to plug in the FTDI cable.
The ArduPilot-Mega has a few more ports and therefore two-way communication will be possible.
Cheers
Sim
