Tags:
Permalink Reply by hopslink on October 29, 2010 at 3:15am
Permalink Reply by Dean Lamborn on October 29, 2010 at 7:51am
Permalink Reply by Colin Johnston on November 18, 2011 at 11:03pm PID control loop gains are tuned for a specific response for a specific type aircraft but can accommodate some variance while still proving good control and stability. It is very possible that if you change the plant parameters, then you'll have to re-tune the PID gains(Kp,Ki,Kd). If you model your the plant(Heli/Plane, and possibly servos) behavior then you can investigate PID gains that provide sufficient control response for a given input(step,ramp) or for a variety of inputs. Aerodynamic Models of Helicopters are hard to develop, easier for a Plane, but you have to be very knowledgeable in Controls, Dynamic Modeling and Simulation, Aerodynamics and of course Matlab/Simulink. Without a sophisticated computer model of your RC, you are essentially doing this manually by using your brain, vision, and sensitivity on the controls to measure the plants response to varying inputs(flying) with certain gains..This is called experimental flight testing!..Every newly designed plane or helicopter goes through it. Engineers want to understand the relationships with models, parameters and flight performance.
Moment of Inertia, Mass, Stability Derivatives, Control Derivatives, Lift, Drag, Thrust, Weight are just a few parameters in these Aerodynamic models.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.133 members
51 members
314 members
4 members
1292 members
Powered by
