I am working on my first Arduino project.  I have a pretty good understanding of the hardware, and some basic→moderate programing skills.  I have familiarized myself with the basic Arduino programming language, and the hardware requirements, but I am looking for some help/advice on my project.
I am creating an autopilot for a trolling motor on a boat.  I am proceeding in several phases.
Phase one – Integrate the hardware controls to manipulate the motor, and create an Arduino script that allows me to control it from a wired remote.  ***Complete – See notes below***
Phase two – Integrate a 3-axis magnetometer (an possibly 3-axis gyro and 3-axis accelerometer to steady the readings) to allow the Arduino to control the direction and maintain a heading.
Phase three – integrate a gps unit and create trolling modes (i.e. zigzag, figure 8, or loop)
Phase four – integrate NMEA output from external GPS (i.e. garmin) into Arduino project to allow the Arduino to follow waypoints.
Phase five – Create wireless control.
My progress thus far incorporates a potentiometer and servo to control the throttle (attached to the carb linkage), and a pair of relays powering a hydraulic pump and cylinder to control the steering.  I would like to use a linear actuator rather than hydraulics.  I am currently using an Arduino Uno, and I know I will likely need a mega to handle the needed I/O ports.
For the wired control, I am using an (on)/off/(on) toggle for the steering switch, an on/off/(on) switch for the run/idle and mft (momentary full throttle), an off/(on) switch for the start and stop buttons, and a 10k potentiometer for the throttle control.  This requires a large project box for the wired control, I would like to slim this down by making a custom PCB based keypad, but I would need to waterproof it, I would appreciate any suggestions on creating a DIY rubber keypad.
Here is my script:
// Trolling Motor Throttle Control //
// by Adam Rogowicz a.rogowicz@gmail.com //
#include <Servo.h>
// hardware libraries:
Servo myservo;  // create servo object to control a servo
const int buttonPin_idle = 7;  // set the pin number of the run/idle button ** on/off button **
const int buttonPin_mft = 6;  // set the pin number of the mft button ** off/(on) button **
const int buttonPin_left = 5;  // set the pin number of the left control button ** off/(on) button **
const int buttonPin_right = 4;  // set the pin number of the right control button ** off/(on) button **
// !!not in use yet!! // const int buttonPin_heading = 8;  // set the pin number of the set heading button
const int relayPin_left =  3;  // set the pin number of the left control relay ** NO relay **
const int relayPin_right =  2;  // set the pin number of the right control relay ** NO relay **
const int relayPin_start =  11;  // set the pin number of the start control relay ** NO relay **
const int relayPin_stop =  10;  // set the pin number of the stop/kill engine control relay ** NC relay **
const int buttonPin_start =  13;  // set the pin number of the start button
const int buttonPin_stop =  12;  // set the pin number of the stop/kill engine button
// variables:
int buttonState_idle = 0;  // variable for reading the run/idle button status
int buttonState_mft = 0;  // variable for reading the mft button status
int buttonState_left = 0;  // variable for reading the left control button status
int buttonState_right = 0;  // variable for reading the right control button status
// !!not in use yet!! // int buttonState_heading = 0;   // variable for reading the set heading button status
int relayState_left = 0;  // variable for reading the left control relay status
int relayState_right = 0;  // variable for reading the right control relay status
int relayState_start = 0;  // variable for reading the start relay status
int relayState_stop = 0;  // variable for reading the stop/kill relay status
int buttonState_start = 0;  // variable for reading the start button status
int buttonState_stop = 0;  // variable for reading the stop/kill button status
int potpin = 0;  // analog pin used to connect the potentiometer ** 10K pot **
int val;  // variable to read the value from the analog pot pin
void setup() {
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  // initialize the pins as an input or output:
  pinMode(buttonPin_idle, INPUT);
  pinMode(buttonPin_mft, INPUT);
  pinMode(buttonPin_left, INPUT);
  pinMode(buttonPin_right, INPUT);
  pinMode(buttonPin_heading, INPUT);
  pinMode(relayPin_left, OUTPUT);
  pinMode(relayPin_right, OUTPUT);
  pinMode(relayPin_start, OUTPUT);
  pinMode(relayPin_stop, OUTPUT);
  pinMode(buttonPin_start, INPUT);
  pinMode(buttonPin_stop, INPUT);
void loop() {  // Start of loop
  buttonState_idle = digitalRead(buttonPin_idle); // read the state of the rin/idle button value
  buttonState_mft = digitalRead(buttonPin_mft); // read the state of the rin/idle button value
  buttonState_left = digitalRead(buttonPin_left); // read the state of the left control button value
  buttonState_right = digitalRead(buttonPin_right); // read the state of the right control button value
  buttonState_heading = digitalRead(buttonPin_heading); // read the state of the set heading button value
  // !!not in use yet!! // relayState_left = digitalRead(relayPin_left); // read the state of the left control relay value
  // !!not in use yet!! // relayState_right = digitalRead(relayPin_right); // read the state of the right control relay value
  buttonState_start = digitalRead(buttonPin_start); // read the state of the start button value
  buttonState_stop = digitalRead(buttonPin_stop); // read the state of the stop/kill button value
  // !!not in use yet!! // relayState_start = digitalRead(relayPin_start); // read the state of the start relay value
  // !!not in use yet!! // relayState_stop = digitalRead(relayPin_stop); // read the state of the stop/kill relay value
  if (buttonState_start == HIGH && buttonState_stop == LOW) {  // Start engine statement
    delay(15);
    digitalWrite(relayPin_stop, LOW);
    delay(15);
    digitalWrite(relayPin_start, HIGH);
    delay(15);  }
  else if (buttonState_stop == HIGH && buttonState_start == LOW) {  // Stop/Kill engine statement
    delay(15);
    digitalWrite(relayPin_start, LOW);
    delay(15);
    digitalWrite(relayPin_stop, HIGH);
    delay(15);  }
  else {
    digitalWrite(relayPin_stop, LOW);  }
  if (buttonState_idle == HIGH) {   // run/idle button statement
    myservo.write(15); }  // if run/idle button engaged, servo to 0 position
  else if (buttonState_mft == HIGH) {   // mft button statement
    myservo.write(164); }  // if mft button engaged, servo to 17 position
  else {
    val = analogRead(potpin);  // reads the value of the potentiometer (value between 0 and 1023)
    val = map(val, 0, 1023, 15, 164);  // scale it to use it with the servo (value between 0 and 180)
    myservo.write(val);  // sets the servo position according to the scaled value
    delay(15); }  // waits for the servo to get there
  if (buttonState_left == HIGH && buttonState_right == LOW) {  // left control statement
    delay(15);
    digitalWrite(relayPin_right, LOW);
    delay(15);
    digitalWrite(relayPin_left, HIGH);
    delay(15); }
  else if (buttonState_right == HIGH && buttonState_left == LOW) {  // right control statement
    delay(15);
    digitalWrite(relayPin_left, LOW);
    delay(15);
    digitalWrite(relayPin_right, HIGH);
    delay(15); }
  else {
    digitalWrite(relayPin_right, LOW); }
}  // End of loop
At this point, I need to know if I need a 3-axis gyro and 3-axis accelerometer to accomplish my goal.  I assume it will help, but I don’t want to overcomplicate my project if it is unnecessary.
I would appreciate any advice on hardware, and I need a starting point for the software for phases two, three, and four, and any advice on hardware for phase five, wireless controller.
I would also love to integrate a means to put the Arduino into sleep mode (low power) when the motor is off.  I am not sure how this would work since the start button would need to be operative while in sleep mode.  I would also like to incorporate a small LCD in the wired control, a way to determine the engine RPMs (tachometer), and display RPMs, Mode, water temp and???  Another thing I would like to incorporate if possible is a way to read depth from a sonar transducer, and have the autopilot follow a bottom depth.
