I am very new to this scene and I have the following hardware:
ArduPilot (with 328 chip)
ArduIMU V2 Flat
Venus GPS module (set to 38400 baud and NMEA)
6 channel receiver
servos, ESC, etc...
I have loaded the auduPilot 2.6.2 code on the audupilot and have the following settings:
#define SHIELD_VERSION 1
#define AIRSPEED_SENSOR 0
#define GPS_PROTOCOL 3
#define GCS_PROTOCOL 0
#define ENABLE_Z_SENSOR 0
#define XY_SENSOR_LOCATION ROTOCOL 0
#define POSITION_1 MANUAL
#define POSITION_2 STABILIZE
The rest are add defaults. The IMU has code version 1.7 loaded and PRINT_BINARY is 0. The IMU GPS protocol is set to 1 and I get the followign output from the serial terminal (only powering the IMU - no ardupiot connected): (and some debug commands set)
???Welcome...***
???You are using Hardware Version 2...***
???Software Version 1.7***
???Ground Start!***
???Ground Start!***
421.31
411.99
425.65
531.26
467.39
518.61
???Ground Start complete
!!!VER:1.7,TOW:0***
!!!VER:1.7,TOW:0***
!!!VER:1.7,TOW:0***
!!!VER:1.7,TOW:0***
!!!VER:1.7,LAT:240014600,LON:1209987900,ALT:0,COG:0.00,SOG:0.00,FIX:1,EVZ:0.00,SAT:0,TOW:0***
!!!VER:1.7,TOW:0***
!!!VER:1.7,TOW:0***
etc....
I then reload the 1.7 to the IMU but this time with PRINT_BINARY 1 set.
I have connected the IMU to the AP and the GPS is connected to the IMU. I have soldered the throttle fix and I have connected channel 5 to the CTRL. The IMU is connected as described in :
http://code.google.com/p/ardupilot/wiki/ArduIMU
When powering on the setup, I get a flashing red light on the venus GPS and a GPS lock (solid blue) light on the IMU and a flashing blue GPS lock on the AP. The green power led on the IMU is also on and on the AP the red power and yellow STAT led's are also on.
I can control the servo's from the transmitter and they seem to be working ok. When I switch the channel5 on the transmistter (there is only 2 settings - not 3) the red mux led lights up.
In my settings for AP, this should mean I am in STABILIZE mode, but when tilting the moving the IMU no servos move?
If I hook up the FTDI RX to the TX line from the AP - I get the following on serial(38400 BAUD)
{[[»¿¯mmU»¿¯{o»_mo;=¿79.ª**ÍÊ«««}[_»¿¯Woo»¿¯[oo»¿¯_{o»¿¯{[[»¿¯mmU»¿¯so»_mn:=?79.ªª+ÍÊ^_^¿í¿oo¿w_[¯¿
and it scrolls pretty quickly. I tried changing the BAUD and it has no significant effect.
My questions are:
1. Is hooking the ftdi to the TX on AP the right way?
2. If not 1 above then how do I hook it up to a GroundStation to see pseudo telemetry?
3. Have I forgotten anything? Anything missing in the setup?
Many Thanks
Tags:
Permalink Reply by Tonino on August 7, 2010 at 5:16am
Permalink Reply by Manoel de Deus Mascarenhas Filho on November 15, 2011 at 4:28am
I'm also have similar problems.
The difference is that I'm using EM406 GPS card connected to the IMU and the AP connected to the notebook through the cable FTDI (except for pins 3 and 4), because my modem Xbee failed. use ArduImu 1.8.2 and ArduPilot 2.7.1. ArduPilotGCS beta2 installed but I do not have installed correctly LabView (i3 notebook with Windows 7 64x).
I did all the individual tests of the hardware (GPS, IMU, radio, VShield2), and the AP recognizes the radio when in the MANUAL mode,always without problems. Turning everything on screen debug GCS HEX characters appear, but the GCS does not interpret its (zero throttle, artificial horizon listing, GPS without values).
Questions: 1 - Is it possible to connect the AP via FTDI without connecting pin 3 and 4 (VCC and RX)?
2 - How to know that LabView is working properly? HEX characters on the screen DEBUB GCS indicate proper functioning?
3 - Why the GCS does not plot my plane in the correct GPS coordinates, even after setting the GPS reception?
4 - Why not plot GCS accelerator or wind speed?
I think I have a connection problem between the AP and SCG. Can anyone help me?
grateful
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
24 members
1297 members
79 members
183 members
Powered by
