Hi Guys, I ordered a The Hunter-Vtail frame from qcrc.ca and was wondering can ArduPilot Mega 2.x support this frame ???
(http://qcrc.ca/shop/index.php?main_page=product_info&cPath=7&am...)
Tags:
Permalink Reply by Björn Videnberg on April 20, 2012 at 12:11am Search for Matt Wellington on this forum and you will find some v-tail usage of the arducopter. His got a blog with some entries. Those blog entries are about Octo/hexa though V-tail It's not nativly supported as far as I know. Maybe his got Arducopter mixing code examples available if you want to fiddle around. Just a thought.
I would like to see predefined v-tail frame setups in the Arducopter, would be nice. As there are frame kits available commercially for Quad Vtail, an optimized motor mixing for Q-Vtail in Arducopter would be nice.
I would guess Y4 mixing works (close in mixing), but not optimal. haven't tried that, just read it works. I think you can read about that at multiwii forum. I have only used Q-Vtail using multiwii and defining custom motor mixing values for this. People say Y4 mixing works for Q-vtail on multiwii but not optimal.
Multiwii got native v-tail support for quad nowdays (2.0), as predefined config option.earlier you had to go for Y4 or write custom mixing in Multiwii. In Multiwii is also very easy to write your own motor mixers, due to clever design regarding the motor mixers.
Permalink Reply by Marc LE BRET on April 24, 2012 at 2:38am Hello,
I fly custom maid V-Tails at home.
I have one with inverted V-Tail (140° angle) and another one "normal" V-tail with an angle of 120°.
Both are flying with MultiWii Y4 settings. On the normal V-Tail (same aspect than your ordered frame), I just crossed the Aft motors to avoid reversing code in the Yaw control.
I have also an Y6 with APM2. I just modified it with a V-Tail. The 120° setup is the same as above.
Flight is OK in Y6 APM2 config. You can see it near the end of the Share info thread.http://www.diydrones.com/forum/topics/share-your-drone-info-thread
As the V-Tail angle is close to 90° on your frame, you may have to forward your CG in order to save power at the tail (0,707 efficiency only due to V-Tail config).
Marc
Permalink Reply by Max Yeo on June 9, 2012 at 10:45pm Hi Marc,
So your VTail where do you change the setting ??
Max
Permalink Reply by Marc LE BRET on June 9, 2012 at 11:26pm Hello,
No change of settings (I use Y6 settings). I just have Aft Left Motor CW and Aft Right Motor CCW in order to get normal Yaw control.
Marc
Permalink Reply by Max Yeo on June 9, 2012 at 10:44pm Hi Bjorn,
I tried searching but no luck .....Thanks anyway
Permalink Reply by Björn Videnberg on June 10, 2012 at 12:01am http://diydrones.com/profiles/blogs/new-vtail-8-build-started?xg_so...
There you have Matts page at diydrones, it might be the place to ask him regarding custom mixing for v-tail. he is disucussing mixing there. I don't think his so active there, but I guess the web site will send mails, that discussion are done at his page. I think its worth a try :=)
Seems like he started with Y6 and modified it for octo v-tail. Wouldnt be hard to do same mod for quad v-tail.
My quad v-tail based on multiwii worked perfect with default settings for the predefined quad-vtail. Used to mix my own in earlier multiwii releases, when there where no predefined option. Haven't tried v-tail on my AC2 yet, it's used for other purposes, but It would be interesting to test with AC controller as well. So pls write regarding your findings and results.
Permalink Reply by Jeremiah Wolf on Sunday It would be great to be able help out with the development of this platform with the APM, however the availability and access to this frame is severely hindered by the current production limitation and location of production. How do you plan to address this and get it within the United States for example? What is the possibility to get some licensing agreements in place for production? I would be willing to explore this with someone if they agree.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
1290 members
51 members
11 members
182 members
Powered by
