Hi !
I'm using non-Mega Ardupilot with
non-Mega ArduIMU+ V2 now. I need more channels to control, so APM looks nice for me. Is it possible to replace AP with APM, leaving old ArduIMU+ in place ? I know the new IMU is much more precise and full of feathers, but...
Tags: ArduIMU+, ArduPilot, Mega
I'm afraid not. You'd basically have to rewrite the APM code, which would be a huge job.
Old and new IMU protocols are different ? Or APM cannot work without new functionality of Mega IMU ?
I've been using the Ardupilot with Arduino 0018 version code.  This allows you to use attach more than 2 servos using servo.attach and writeMicroseconds commands.  I've tested it with 3 outputs but 4 should work fine.
I also modified the IMU to write "sentances" of output i.e. GPS data and attitude data on separte lines like Ardupilot is used to.
If you use the code from Ardustation, you can get ArduIMU to talk to Ardupilot this way.  The stabilization and navigation code becomes much simpler
Thank you. I'll try this way.
Any luck so far? I'm gonna need to connect ArduIMU+ v2(flat) to ArduPilotMega.
No progress yet. No time for hobby. Sorry. :-(
