I want to try making a Canard - Elevon platform for the ardupilot.
The reason is that I can fit all the electronics into the fuselage easily and the control linkages are pretty simple. Another main reason is that CG balance is easy to do while switching around batteries or cameras.
the problem is that, there is no elevon splitting with elevator option right now, but what if I do ailerons, and elelvators, and just use a hardware mixer for the elevons?
another option would be some how geting an AUX channel for elevator set up, if anyone has any experience with this, i would appreciate it.
this is the R/c maiden of my design
Permalink Reply by Macboffin on November 11, 2011 at 7:21am Mechanical mixer very easy,use the elevater servo to slide the aileron servo, from which two outputs, one to each elevon.
Permalink Reply by madhuran wilson on November 13, 2011 at 6:48pm this is a pretty neat setup ill look into this... but i think a digital solution is more viable for my aircraft
Permalink Reply by Johnathan Grieger on November 13, 2011 at 4:58pm It is possible to use digital chanel mixers such as:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
all you do is plug the elevator and aileron outputs into the mixer and it will give a combined output signal to each servo on both wings.
Permalink Reply by madhuran wilson on November 13, 2011 at 6:48pm yea.. i think i will get one one this and try it out thankyou for the link
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
184 members
11 members
182 members
1290 members
Powered by
