Hi, I am able to get my quad flying perfectly in stable mode without GPS hold working using ArduPiratesNG - in the Arduino software I chose AP_GPS_MTK16 (DIY Drones 1.6), and in the Configurator it shows that the flight software version is V2.01.
The problem with this is that GPS does not work - in terms that the red light is blinking (no GPS information registered).
However, if I change the comment line in Arduino to use AP_GPS_MTK (DIY Drones 1.4), then in the Configurator, the flight software version is GPS_MT, and the red light stays on solid, and it 'seems' that the GPS is communicating with the quad.
The problem when I use the AP_GPS_MTK (DIY Drones 1.4), is that my quad does not fly at all - even after re initializing and re callibrating everything.
I am using ArduPirates - not ArduCopter.  Is there some kind of conflict between the GPS firmware? Or am I missing a critical step in this.  I have researched and found some tweaking of Arducopter (that is, changing or setting of protocols) but this option isn't available in ArduPirates.
Hoping for some insight,
Rich
Hi Rich:
What version of the firmware is on your GPS?  The firmware version on the GPS must match the firmware you have selected in the code.  There is a section in the wiki on updating your firmware for your GPS (I am assuming you are using the DIYdrones Mediatek GPS).  FYI - do not assume that if you recently bought the GPS unit that it will have the latest firmware on it.  Reasonable assumption, but still an assumption....
This may or may not help, but it can't hurt to make sure you have the latest firmware regardless.
John
Thanks John, yes using DIY MTK GPS
I've been doing some reading in other threads - seems quite complicated.
Also it would appear the only way to update the firmware is by purchasing an FTDI cable... bugger
Rich
From what i have read it seems that ArducopterNG supports both 1.4 and 1.6 MTK firmware.
It would appear that ArdupiratesNG only supports 1.6
Perhaps it would be faster and more cost effective to un-instal pirates and run the ArducopterNG than to order and wait for some dumb arsed cable that makes my DIYdrones MTK work like it should have in the first place... thats assuming i don't stuff up when soldering pins to the MTK in order to plug the freaking cable into it.
any thoughts appreciated - Rich
Hi Richard,
I've got this to look forwards to myself as well. I've been putting it off until i get my magneto back from jDrones. At first i was planning to use the pass-trough sketch that was originally mentioned, but thats not working with the MTEK firmware updater apparently.
So rather than solder to the MTEK (as my cack-handedness is bound to screw something up as everything is so tiny) i was planning seeing if i can make one of these out of the spare GPS cable and headers i have lying around
http://store.diydrones.com/FTDI_GPS_Adapter_cable_15_cm_p/ca-0001-0...
(for the sake of $1.75 i would order one, but 1. i can't as its out of stock and 2. shipping to the uk is likely to be 10x the cost of the cable)
still needs the FTDI cable - but less risk soldering directly to the GPS.
I just need to work out the wiring as the only documentation i could find is for the magneto but the headers are labelled differently.
is anyone able to help with the wiring / pin out config at all?
