Hey all,
I've been using the 3DR radios successfully on my ArduCopter for about 2 months now. I recently ported the radio and my APM to a newly built Skywalker 168cm with the hopes of an AP/FPV enabled fixed-wing aircraft.
After I uploaded the most recent ArduPlane software (2.5), I am having trouble reading telemetry from the APM on the MP. I don't think the radios are a problem since they've worked in the past and they both display a solid green LED when I power the aircraft radio WITHOUT connecting TX/RX to APM. However, under normal circumstances, when I power the APM and thus the connected aircraft radio, it immediately displays both a blinking red and green LED and fails to connect to MP (timeout error).
(I do not have the USB connected at the same time)
Has anyone run into this error before? Perhaps I am overlooking something simple.
Thanks,
Franco
Tags:
Permalink Reply by Jake Stew on August 18, 2012 at 12:05am > I don't think the radios are a problem since they've worked in the past and they both display a solid green LED
Then test the radios first before asking for help. If they work then don't title your thread to imply that people are having problems with the radios, and don't post in the 3DR radio forum.
Permalink Reply by Franco Scipioni on August 18, 2012 at 12:25pm You're right, totally should not have posted in this forum. Will re-post where appropriate.
However, I don't think my title is misleading. Especially after reading my post, it's pretty clear what is being implied here.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1295 members
8 members
24 members
688 members
185 members
Powered by
