Can i use APM 2.0 with my nitro car?Or i need the ESC?
Tags:
Dinos,
Yes, I would say that you can use your APM 2.0 with your nitro car. However, you might want to be aware of the following:
The ignitions on nitro engines make a lot of RF noise that can play havoc with the APM so it should be well shielded.
Also, most electric and, I assume nitro engines, require neutral to be at 1.5ms with full throttle at ~2.0ms and full brake at ~1.0ms. Airplane throttles go from ~1.0 to ~2.0ms so you will have to resolve this inconsistency.
Just a thought.
TCIII
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1283 members
24 members
180 members
4 members
5 members
Powered by
