Where can I get the full ArduRover code for upload to Ardupilot Mega, I wish to try my hand at an autonomous ground vehicle
Kind Regards
Tags:
Permalink Reply by Petrus Botha on January 11, 2012 at 2:05pm I am currently downloading
Permalink Reply by Petrus Botha on January 11, 2012 at 2:59pm I have downloaded the complete file but cannot make any sense from the wiki as to compile and upload the code to APM, can anyone provide some more info please
Permalink Reply by Petrus Botha on January 12, 2012 at 12:45am Is there any support for Ardurover?
If you want to load the code into your APM you just connect it via USB (or via FTDI cable if you are not using IMU board) Then you will need to use arduino IDE to upload the code, more details on this can be found http://code.google.com/p/ardupilot-mega/wiki/Code
If you are not using windows 7, you will probably also need to install the FTDI drivers, more infor is on the ardupilot mega wiki
Regards
UnmannedTech Shop
Permalink Reply by Petrus Botha on January 12, 2012 at 5:23am
Permalink Reply by Jesus on February 7, 2012 at 1:04am Hi Petrus:
Where did you get the ardurover code??? Because I´ve looking for in the wiki but I dont founf it, only some code that there is in the Rover configuration page.
Permalink Reply by Petrus Botha on February 7, 2012 at 1:36am The code is available from https://github.com/arktools/ardupilotone
select the zip button from the top of the page to download the code as a zip file, follow the install instructions.
I have placed my ardurover project on the side for now.
To compile you must use the Arduino relaxpatch available from http://code.google.com/p/ardupilot-mega/downloads/detail?name=ardui...=
You will also need to delete all your libraries in the Ardurover.pde and replace with the following
// Libraries
#include <DataFlash.h>
#include <FastSerial.h>
#include <SPI.h>
#include <Wire.h>
#include <AP_Common.h>
#include <APM_RC.h>
#include <AP_RangeFinder.h>
#include <GCS_MAVLink.h>
#include <AP_ADC.h>
#include <AP_DCM.h>
#include <AP_Compass.h>
#include <Wire.h>
#include <AP_GPS.h>
#include <AP_IMU.h>
#include <APM_BMP085.h>
#include <ModeFilter.h>
#include <APO.h>
#include <AP_AnalogSource.h>
#include <AP_InertialSensor.h>
#include <AP_PeriodicProcess.h>
#include <Arduino_Mega_ISR_Registry.h>
Hope this helps, there is not a lot of support for ardurover
Permalink Reply by m00se on February 28, 2012 at 4:32am hi .
im new to the forums and trying to get a boat working using the rover code,
i have one esc and one servo just like the rover so it should work ,
i have done everything you just mentioned above,
how can i get it to connect to the ground station ? any ideas?
Permalink Reply by Adam Scriven on June 23, 2012 at 9:36am I'm not sure if this is concerned with the new or old versions of the ArduRover code, but it does predate the current ArduRover development. The 'ArduRover' link in the navigation has been updated to point to a recent major change in ArduRover that is reportedly much better than the previous version.
I haven't had a chance to test it myself, but FYI for those in here that may not have noticed it yet.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.314 members
4 members
1292 members
684 members
110 members
Powered by
