I noticed this as a quick way of overcoming any line interference that might cause issues with any of the MaxSonar sensor.
http://www.maxbotix.com/tutorials.htm#New_Flash_UAV_and_Mobile_Robo...
Permalink Reply by Jason Willis on April 6, 2012 at 12:09pm Have you tried it with success? I ordered a MaxSonar sensor today and if this works I will just install one from the start to save any headaches.
Permalink Reply by andycross1 on April 6, 2012 at 12:22pm Hi Jason
Not yet, but looks quite sensible to do anyway as there is a lot of noise being pushed out by the ESC's
Yes this is a well known solution to add the filters... also use shielded cables (old mouse cables are good for that)
works great and reduce the noise! without it your Sonar might "work" but the accuracy is not as good as it should be and there will be some spikes in the reading.
Dany
Permalink Reply by Jason Willis on April 7, 2012 at 3:17pm Thanks for the info Danny! When you say use shielded cables do you mean on the wires running to the sonar or for all of the wires around it?
1289 members
681 members
248 members
57 members
Powered by
