Arm/ Disarm APM
In setting up arduplane on an APM 2.5 board that will go in a skywalker 1900, I notice that I do not have the ARM Disarm function that I am used to with the arducopters.
I start off in Manual mode on the controller and immediately the prop will spin with input from the throttle stick. Traditional disarm commands through the controller have no results. Also when clicking the Arm/Disarm button on mission planner I get an error message "unable to arm/disarm MAV".
I am going through the wiki again trying to find documentation about this issue but any help would be greatly appreciated.
    The latest plane release should have the arming/disarming feature similar to copter.  It's off by default though.  I think there's a parameter called ARMING_REQUIRED that can be set to 1.
