Attopilot 45A sensor, incorrect readings?
I'm using a Attopilot 45A sensor with a Pixhawk and 6S batts. The problem is that a) the voltage reading is way off using the Attopilot 45A presets and b) once the voltage stabilizes it doesn't change again, like it's stuck.
The readings aren't much better using "other" and measured current with the same problem of the voltage "sticking"and failing to update.
Anyone using this 45A sensor successfully?
    For some reason the text of my thread didn't show.
    Should be good now.
    Anybody using a 45A Attopilot sensor with 6S batteries?
