I have already asked this question but can't find an answer. I have mission planer 1.1.99 installed on my computer (windows 7 64 bit).
When I open Mission Planer a little window open and advise that there is an update available. If Iclick yes, everything download OK until the part which says "Getting Open T K. compatibility.dll: 0.5%" Then I got the message" Update failed The request was aborted: The connectionwas closed unexpectedly.
Could some body from the team give me an idea of what is wrong? I do not have time limit activated on my computer. However if I down load the .exe from the download site I have no problem in installing the software. Cheers Pierre
I didn't have any trouble myself, but have you tried rebooting and trying again? If that doesn't work, uninstalling and doing a fresh install?
Hi Chris, yes have done that even deleted MP from the computer and redownloaded the .exe file from the site, no dice.
cheers Pi
Perhaps you have an antivirus software mistakenly blocking the download?
Thanks for your comment.The download is fine only the part pertaining to the dll mentioned fail. I have not changed my computer set up or antivirus software. And I did not have the problem with earlier versions of MP. Pi
I found that some updates did not set permissions properly which affected the program.
Now, whenever there is an update I quit MP and then run it again as 'Administrator' and all is well.
It seems some files are set to admin only and running as a user the update can't change these files or directories.
Thanks Mike. That's what I do now go to the download site and run the Mp in administrator Pi.
When you install via MSI, the permission should be change to grant all users full access, the zip file however does not do this, so it depends on how you install the planner.
Thank you Michael. Will look into it. however it is not a problem if I download the zip and do a run with administrator priviledge everything is OK. And the advantage for me is I can go and check if the new relise contains important updates. Pi.
