Autonomous drone making for wro need help!!
Hello there,
Iam planning to make a drone that is autonomous and checks soil, air and luminance I need some assist in making it could u please tell what motors I must use to lift a 3kg weighing drone please tell me how much kv must the motors have pls help!!! the drone is gonna be a quadcopter pls help me what motors i must actually use
  • hello,
    This size craft is very popular but a waster form 600kv to 1000kv 12-13 inch props , motors combo.  For the same price you can get 380KV motor and 16 inch props 3508 to 4110, 4114 motors. I would go with the larger lower KV motors gives you more flight time with larger props. 4S to 6S battery depending on craft.
    • actually my drone's weight is 3kg will 1400Kv motor fit my need or should i go for a 3000Kv motor thnx for the help
      • what flight time you get with 1400kv motors?
  • You can try the DJI E800-Set. This is used at the Inspire 1 too, which is roundabout 3kg heavy.
  • guys iam making a quadcopter pls help me pls
