Hey guys (mainly 3DR, but anyone who has input/suggestions)
I have quite a few APMs and three APM2. I've got one that I haven't flown (an APM2) and I just put a case on one of them... I believe, in fact, that I've hadn't yet flashed this one, as it does not boot.
I just slapped a case around all my APM2's, and was prepping them all with a custom 2.40 HIL codebase. This process was seamless for my HIL-dedicated APM1, and for two of my APM2s, but I encountered a problem with this final APM2. I'm looking for suggestions about anything I may be overlooking before contacting support and asking them if there is something I can do, or if I should RMA.
Here is the environment:
Build Environ #1
- Mac OS X 10.7.4
- Arduino 1.0.1
- ArduPlane 2.40 (GIT, release, and custom, all behaves the same way)
Build Environ #2
- Win7 64bit on Parallels 7, latest patch, on Mac OS X 10.7.4
- APM Planner 1.0.84, 1.1.92 mav 0.9, 1.1.94 mav 1.0, 1.1.96 mav 1.0 (each attempted)
- ArduPlane 2.40, ArduPlane 2.40HIL, ArduCopter 2.6 Quad, QuadHIL attempted
Here are the symptoms:
In build environment #1, uploads of small sketches are successful (multiserialmega, etc)
Uploads of GIT, AP2.40HIL release, custom AP2.40 all compile, but uploads fail with:
Binary sketch size: 113,778 bytes (of a 258,048 byte maximum)
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x13
avrdude: stk500v2_paged_write: write command failed
Meanwhile, in build environment #2, the results are always the same:
APM Planner detects that the EEPROM needs to be erased, begins to upload, then fails with the standard System.IO.IOException (most likely getting the timeout shown above).
In cold boot, the board does not boot with the normal LED behavior, on first connecting the USB cable, the APM2 (i.e., not daughterboard) blue LED flashes briefly, afterword none of the A, B, or C LEDs are lit... no alternating red, blue LEDs. The daughterboard LED behaves as expected, and the green power LED is lit. The TX/RX behave normally initially during an upload attempt, but when the upload fails, one of the TX/RX LEDs remains lit for a few seconds, and both go dark. This supports what the Arduino IDE reports in terms of what is going on.
I tend towards suspecting a DFU firmware timeout issue, but by all accounts, I have .0001, if the firmware is stock 8UT (I don't know that it is...thus I haven't tried to re-flash)
Additional background:
Although upload errors are seen both within Windows and natively in Arduino 1.0.1 on a Mac, I did already review the windows-side serial driver, everything is just as you'd expect (and works for the three of my other units, same cable, tried different cables, every combination, only this APM2 has the issue, no matter which [working] cable is used. I also uninstalled/deleted drivers, reinstalled, disabled/enabled drivers, changed com ports (four times, to lower/higher numbers) but as I said, uploads fail in both environments.
This APM2 hasn't flown, and I'm pretty sure I haven't used it yet, I don't think I've even attached an RC RX yet to this one yet. I could be mistaken, but other than running up MultiSerialMega, I haven't been able to push anything that runs the CLI to do things like poke about with tests. I could push a much older version of the code, but I'm not certain what value that might have, since I only plan to run "modern" code on this board....
Thoughts or suggestions welcome. Or should I contact Jordi & team for an RMA?
Tags: &, APM2, Errors, System.IO.IOException, avrdude:, stk500v2_ReceiveMessage():, timeout
I'd get a RMA.
Permalink Reply by Michael Pursifull on July 8, 2012 at 9:12pm Thanks Chris - I sort of suspect it's related to http://code.google.com/p/arduino/issues/detail?id=392 but aside from not having an ISP handy at the moment, I wasn't sure what firmware/bootloader should be present, and figured if it is b0rked, someone might want the chance to look it over first.... and it's also too easy for me to overlook something obvious, so I figured I'd ask first. I get great service from 3DR filling my orders, I didn't want to tie anyone up with a silly mistake on my part.... and slow down my/our orders ;-)
Permalink Reply by Yogesh Girdhar on August 18, 2012 at 8:23pm I am getting the same error for my brand new APM 2.5, which I just received. :(
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.185 members
51 members
24 members
133 members
1298 members
Powered by
