bec module not working
I using 3dr clone bec module.
I calibrated the bec module in initial setup, set measured voltage 12.3 after measuring the battery volt by a multimeter. after a flight, I found that the voltage does not change in the telemetry data and In dataflash log volt in curr ranges from 63 to 133
Is there any setting that can be changed? Can anyone suggest a reliable one in hobbyking?
