I have now done a few good test flights where I'm very happy with the way the APM & airframe have done just as asked!
I have been flying very close by and watching its every twist and turn, I now wish to push out the distance being covered.
When planning a flight over a longer distance which is the best option 1 or 2?
And by longer I mean it will still be in LOS ;o)
Option 1:
Option 2:
Regards
Martin.
Tags:
Permalink Reply by DaveyWaveyBunsenBurner on January 9, 2011 at 12:38pm
Permalink Reply by Johann Van Niekerk on January 9, 2011 at 12:47pm I Agree .
Number one should give you a more accurate flight .
Thank you both for your thoughts, I was thinking the same. The more points it has to hit the more it will stay the course. I have only done a max of about 1/3 of a mile between waypoints, the EZ* has hit each one every time and in some strong winds, like today’s flights were in 10-20 mph cross winds on the longest legs, you could see the plane fight all the way to the waypoints.
Regards
Martin
Permalink Reply by Paul Thompson on January 9, 2011 at 4:16pm G'day Martin,
Option 1 is probably a better way to flight plan, But Long legs will still work fine even with strong cross winds. I have done many long flights with individual legs of more than 5km and APM performs xtrack navigation very well. If you do any long flights, make use of the elevation graph, It is a great tool for working out a lowest safe altitude.
Cheers
Paul
Martin, If you have a look at the latest APM planner on the SVN it has Elevation Graphing. Just make sure you set your Home alt correctly, as all the other values are based from that.
(or just use the update check on the menu)
Michael
Thank you both for your replies to my question, I look forward to sending the plane on longer missions!
Regards
Martin.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.185 members
24 members
51 members
1295 members
687 members
Powered by
