Tags:
I've actually never mounted a camera on my quad or heli but I'm nealy 100% sure it's vibration. Not sure how you have it mounted but maybe try to isolate it more from the frame.
That strikes me as being motion blurr more than vibration. Just because it seems blurred in one direction, not random. What was the shutter speed?
But it could be vibration. This is a very common problem. You need to isolate the camera properly. Do you have any pictures of your setup.
I believe that camera also had image stabilization. That can actually make things worse. Some cameras just don't do well in aerial photography because their OIS system reacts badly to vibes. The pictures turn out worse than non-stabilized cameras on the same mount. You might try turning off OIS if you can.
Permalink Reply by hightechhobbie on December 18, 2011 at 11:27am Hello my friend, it doesn't seem that you have vibration issues, but i suppose camera is somewere under the wing.. so fairther from roll axis your are the greater the constant movement.. try put your cam near to fuse. second possible problem is that you are blocking the light sensor with your mount and cam "thinks" that you shoot at night and extends exposure time (i thing its at the right side from flash), make a hole or something..
cover camera with your palm and half klik the shutter, its the easiest way to figure out if there is any sensor, if there is, everything should seem brighter thru the screen, also enable flash or manualy put iso to 100-200 max, then extend your hand and travel cam from left to right with 2 sec travel time and check results. lower res to 12mp. if any of this dosent help in flight but pics are fine on ground checks then you should place your cam near fuse.
Permalink Reply by Daniel Gru on December 18, 2011 at 4:05pm We need to know the shutter speed, to be able to help you... if it was below 1/100th, then we have the reason for the motion blur ;-)
Permalink Reply by Haidar Abu Bakar on December 19, 2011 at 1:44am Try setting the camera on Shutter priority. Select at least 1/500 or more shutter speed for a sharp photo.
Permalink Reply by brakar on December 19, 2011 at 1:59am Agree, (I have found shutter speed 1/600 - 1/800 to work well with an un-dampened camera). Besides, turn of all "auto-functions" (zoom, focus, etc), fix focus at "infinate".
Permalink Reply by hightechhobbie on December 22, 2011 at 2:53pm thank you everybody im just waiting for the next sunny day !!!
Permalink Reply by Gareth Rens on December 23, 2011 at 8:57am Its definitely your shutter speed :)
Permalink Reply by hightechhobbie on December 24, 2011 at 9:42am
Permalink Reply by hightechhobbie on December 25, 2011 at 2:59am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.682 members
1289 members
182 members
24 members
248 members
Powered by
