Bormatec Cam Flyer Q parameters problems
I am trying to fix the parameters on Pixhawk autopilot and I am having quite big problems to make it fly good. I must say the i have put a heavier battery than the specified one and the center of gravity is at 110mm and not at 120mm as Bormatec suggests. I would apreciate if someone could share parameters, when I will have it flying properly I would upload mines.
Thank you in advanced ;)
  • Did you had any progress on the best center of gravity and do you have any parameter file you would like to share?
