Busted gyro
I have this 3DR Ardupilot 2.5.2 that experienced a bad crash, did some checks and found out that the x gyro is busted. The plane is shown in MP suddenly banking to the right at around 40 degrees then it slowly decreases and stops at around 30 degrees, while it is actually just sitting in the table. Can I just replace the chip or should I shelf this? I can't even use this as Antenna tracker right?
I tried powering the board via USB port, but the x-y-z gyros are not being powered. And this sudden bank happened multiple times already today while doing bench tests.
3691159297?profile=original3691159206?profile=original
  • anyone?
    • bump
