Calculating the servo angles for specific blade angles
Hi
I am using a 3 servo 120 degree swashplate configuration, I am using a 50 mm servo linkage arm for each servo. I wanted to know if there is a calculation method to find the required change in angle of the servo for specific blade angles. Ie: for a prop blade angle of 10 degrees what will be the required servo angles.
