3DRobotics sells this cable for the GoPro: https://store.diydrones.com/Camera_L_shaped_cable_connector_p/cam-c...
What does it connect to and more importantly what is the pinout and color diagram.
The page does not any description or schematic.
Tags: 2.5mm, GoPro, avout, cable, miniOSD
Yellow is audio, white is video, black is ground, and red is power. You connect it to your video transmitter with a cable like this https://store.diydrones.com/Video_transmitter_cable_connector_p/cam... (I usually put some male pins in between the two female connectors to make the connection) or you can also connect it to your OSD. Good catch though, I will update the listing to include pinout.
Alan
Alan thanks a bunch.
I had purchased one of this and tried to connect it last night.
I was connecting it all wrong (yellow is video, white-left audio, red-righ audio, black-ground.
Another questions.  You mentioned that the red is power.
If connected to the GoPro, is that power to the GoPro or power from the the GoPro?
Or is that used if i'm connecting to a standard UAV camera.
You know my previous post was done last night from memory, but youre right for the GoPro you dont need to connect the red cable. You only need to connect the orange and brown cables. You need ground to complete the circuit or the video signal will not go through. That said, I dont think there is anything wrong with connecting all 3 wires. I have done it both ways and it works.
