Firstly my 3DR radio works awesome!
my question is can 2 "air modules" connect to each other or are they designed only to work with the "ground station" only? thanks in advance
https://store.diydrones.com/ProductDetails.asp?ProductCode=BR-3DR91...
Tags:
Permalink Reply by Jake Stew on May 5, 2012 at 12:12am The air and ground modules are identical with the exception that the ground module has a serial-usb converter.
Permalink Reply by GoProDude on May 5, 2012 at 1:18am ok so your saying it doesnt matter, when i turn on both air modules they will lock into each other correct?
Permalink Reply by James Y. on May 5, 2012 at 6:41am Only if their network IDs and other parameters are the same, as per;
Permalink Reply by GoProDude on May 5, 2012 at 10:13am ok so your saying with the mission software i can make changes to the air modules so 2 air modules can connect to each other?
Permalink Reply by Helldesk on May 5, 2012 at 11:52am Two 3DR radios will communicate with each other no matter what they are, if they have been configured to the same network ID and settings. It does not matter which one is a "ground" module and which one is an "air" module since they are identical. They read and output serial data by wire, transmit and receive it wirelessly to and from each other and that is all. Leaving your plane on the ground and doing a parachute jump with your ground station laptop would still have your falling "ground" module communicating with the grounded "air" module. :p
Basically the radios just take care of the business of a serial cable. A plain old serial cable does not care either which end is which.
Also, here is a grammar tip. Repeat after me: "So you're saying". As in "So you are saying". Not "your"!
Permalink Reply by GoProDude on May 5, 2012 at 11:55am Two 3DR radios will communicate with each other no matter what they are, if they have been configured to the same network ID and settings. It does not matter which one is a "ground" module and which one is an "air" module since they are identical. They read and output serial data by wire, transmit and receive it wirelessly to and from each other and that is all. Leaving your plane on the ground and doing a parachute jump with your ground station laptop would still have your falling "ground" module communicating with the grounded "air" module. :p
Also, here is a grammar tip. Repeat after me: "So you're saying". As in "So you are saying". Not"your"!
what are you the grammar police? im typing from my phone so excuse me for not following your "proper grammar tips". besides you understood me fine, next time dont be a jerk to new people trying to learn something new. wow.
Permalink Reply by Jake Stew on May 7, 2012 at 10:42am Yes, he is a sargent first class grammar officer. Don't smart off to him or he'll haul you off to grammar re-education class or give you after school detention.
He did give you some advice whilst correcting your grammar, so a nice boy would just thank him and roll his eyes.
Permalink Reply by GoProDude on May 7, 2012 at 10:58am Yes, he is a sargent first class grammar officer. Don't smart off to him or he'll haul you off to grammar re-education class or give you after school detention.
my gosh is it all douche bags on this site or what? people with real questions need help and these are the kind of responses you get. go annoy others will ya.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.5 members
1282 members
183 members
674 members
116 members
Powered by
