  • Just keep in mind that Opto ESCs dont have a BEC onboard so there is no 5V output on the servo leads. You will need an ESC with a BEC onboard
    • yep, i have one Mystery with UBEC... I will try tonight!
      thanks everybody!
  • T3
    I have successfully done this a few years ago.  Works fine.  I had been running off one of the motor ESCs, but it kept browning out the ESC and causing that motor to cut for 1-2 seconds (too much heat I think).  So you're right to use a fifth ESC to power the APM, at least until you can get a real PM.
  • MR60
    If the old ESC has a BEC producing 5V (less than 5.5v) you could use it to power APM ( from the output rail with JP1 on) or make a custom cable to use APM power port (JP1 off). However a PM would be better, cleaner (electrically speaking), provides V,I measurements.
    • yes, i will order the power module anyway, but it's just for a temporary / weekend solution...
      • Will be fine.
        I use an apm 2.6 in my Fms Cessna with the motor esc powering the output side and an sbec to power the input side (jp1 removed) and the minimosd.
