Hello,
I have a Pixhack flight controller, and I am used to changing the ends of cables so that accessories designed to work on the Pixhawk, can plug into my Pixhack instead.
I am seeking clarification on one port in particular. This is the CAN port of the Pixhawk, and where the equivalent pins would be on the Pixhack.
I am trying to connect the Zubax GNSS 2 module because I want to take advantage of having an external barometer.
Here are the pin out on the Pixhack:
3691302644?profile=originalThe CAN port on the Pixhawk is as follows:
Pin 1 = VCC +5V
Pin 2 = CAN_H +12V
Pin 3 = CAN_L +12V
Pin 4 = GND
As you can see in the picture above, there are no pins labelled CAN_H or CAN_L on the Pixhack. There are however, CAN_T and CAN_R. Are these the equivalent? If so, which is which?
  • Hi Chuck,
    Unfortunately, Pixhack doesn't have a CAN bus interface. It offers only a CAN transceiver interface, which requires some external circuitry. I'd suggest to go with Pixhawk or something alike.
    Pavel.
    • Thank you Pavel.
      I have ordered a Pixhawk which should arrive early next week. I will give it a go as soon as it arrives.
    • can transceivers are pretty cheap little boards though on eBay if you are handy with these things...
