Good day everyone - this is my very first post on this forum.
I'm getting a "No Heartbeat Packets Received" error when I attempt to connect my new APM 2.8 controller to Mission Planner.
Here are the specifics so far:
- MP 1.3.31 build 1.1.5696.33420
- ArduCopter v2.9.1b firmware
- Nothing connected to the board except the USB cable
- Board showing 1 solid orange LED and one solid blue LED
- Tried all three USB ports on my Dell Latitude laptop running windows 7 Pro
- The board is listed as COM7 and I've set the baud rate at 115200 (in the device manager settings as well)
- I can connect with the terminal, access the basic tests, and read the unit settings
- I attempted to connect (without success) via radio telemetry and the PM as well, just to see if my USB port wasn't supplying enough juice (not at the same time as the USB cable)
This is my first quad build and my first experience with APM. Any advice on what to try next would be greatly appreciated.
Neil
In the mean time, I'm so impatient that I'm considering just buying another board from a U.S. Supplier so I can keep this project moving. Maybe it's not so bad to have a backup board lying around. Or maybe I'm just making excuses. Or maybe I'm just really hooked on this hobby and don't want to wait...
Update: contacted seller and they asked for more information in the form of photos and/or videos. Took three videos today and sent via email. Hopefully it's enough information for them to see the issue and to resolve my complaint. We shall see...
This Wiki page details the LED's
http://copter.ardupilot.com/wiki/common-autopilots/common-apm25-and...
Note: If you connect in Terminal the board needs to be reset by the reset button or powering down before you can connect via MAVLink.
Thanks for your help.
I also assume you are using the latest version of MP.
In the pic you posted it is stating that the MPU6000 is not starting.
Looks like a faulty board.
Mike, are you able to share with me what a properly booted board looks like in terms of LED's lit and flashing or not? No GPS or compass connected.
Thanks!
First step would be to reflash the firmware.
Any reason you are on the older firmware?
Latest stable release would work best with the latest versions of MP.
Re-flashed with latest firmware and still get the same "No Heartbeat Packets Received" error on connection attempt. In the terminal I get this:
On reboot I get a flashing red LED near the PM connection port that flashes two times.
