Can't find Sonar parameters.
Hi guys,I upload the AC 3.2 Arducopter heli  firmware today.But the sonar parameters RNGFND_PIN      RNGFND_MAX_CM   RNGFND_SCALING   RNGFND_TYPE  can't be founded in parameter list.And the sonar can't be enabled.
I followed this way,but it makes no sense: http://copter.ardupilot.com/wiki/common-rangefinder-maxbotix-analog/
Looking for your answers!Thanks a lot.
  • Hi William - were you able to resolve this? I am on 3.1.5 and latest MP and Sonar option was disabled / could not be checked. I reinstalled MP 1.3.1 and while the checkbox came back along with the option list, the sonarrange and sonarvoltage in flightdate->status shows 0. The Sonar is working though - can hear clicks and sonar test via CLI shows the distances near correctly.
    Worse, the RNGFND_ parameters are not showing up ( MP latest or MP 1.3.1 ) - Please see my post on https://www.youtube.com/watch?v=Rba1ZdL0vyE
    • Some confusion around whether AC 3.2.1 supports Sonar or not. But I upgraded to 3.2.1 and the RNGFND_ parameters appeared. The sonar can only be enabled via these parameters - select the right PIN and Enable = 1 and not from Optional Hardware->Sonar panel. I am getting the sonarrange and sonarvoltage in status. Will be switching to narrow beam Maxbotix XL ( currently using LV-EZ0 and this does not good range or accuracy ). Probably should have invested in a LIDAR-Lite.
      Reboot of APM is required.
      I later on upgraded MP to 1.3.34 as well.
      • Admin
        @Rajinish,
        Did you review this page in the ArduCopter Wiki concerning the sonar Link
        Why are you using MP 1.3.1?
        TCIII AVD
        • Hi Thomas,
          Yes I did see the link you have mentioned. But I also read elsewhere with folks claiming that support for sonar has been taken out from 3.2.
          I was on MP 1.3.34 + AC 3.1.5 but downgraded to see if it will bring back the RNGFND params ( since Sonar checkbox was disabled in optional hardware Sonar panel.
          Now all good.
          Thanks.
          Rajnish
