i cant arm the motors led A doesnt even start flashing. it stays solid green.
i have calibrated esc gone through set up atleast 5x both in mission planner and cli
using acm2.06
the quad was flying perfect yesterday.
the only main change i made was updating firmware
Tags:
Permalink Reply by Rob. S on May 21, 2011 at 2:51pm
Permalink Reply by Rob. S on May 21, 2011 at 11:17pm hey guys
i thought i had worked out the problem but i was wrong.
it seem no one else has this problem.
when i try to arm the motors the green light doesnt flash so i cant arm them
i checked to c if my transmitter was sending a signal and it was
i made sure i had the cli switch in the right place and it is flight mode
i have done esc setup
when i boot the esc i can feel the motors move.
i dont know wat else to try does anyone have any ideas PLS???
Permalink Reply by Vincent Mees on May 22, 2011 at 1:53am Reload the code again. And make sure to reset the eeprom.
I had this on my quad
Permalink Reply by Rob. S on May 22, 2011 at 4:33am just did that didnt work
im goin to go through jani's setup c if i missed something
thx anyway
Permalink Reply by Rob. S on May 23, 2011 at 2:05am
Permalink Reply by Rob. S on May 23, 2011 at 4:16am is there so sort of resetting order i need to follow.
i left my quad for like an hour came back to it and it seem to work but once i changed pids it stoped arming again.
CAN ANYONE HELP ME OUT!!!!!!!!!!!!!!!!!!
Permalink Reply by Rob. S on May 23, 2011 at 2:11pm IN 1: 1921 2: 2016 3: 62 4: 1744 5: 6 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 1776 5: 5 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 1860 5: 2 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 1912 5: 7 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 1997 5: 1 6: 0 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 2165 5: 7 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 2386 5: 2 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 2658 5: 7 6: 3 7: 1000
IN 1: 1927 2: 2016 3: 62 4: 2989 5: 1 6: 1 7: 1000
IN 1: 1927 2: 2016 3: 62 4: 3378 5: 7 6: 2 7: 1000
IN 1: 1927 2: 2016 3: 62 4: 3799 5: 1 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4149 5: 7 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4324 5: 1 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4415 5: 6 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4461 5: 2 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4480 5: 7 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4487 5: 1 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4500 5: 7 6: 3 7: 1000
IN 1: 1927 2: 2016 3: 62 4: 4500 5: 1 6: 0 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4506 5: 5 6: 2 7: 1000
IN 1: 1927 2: 2016 3: 62 4: 4506 5: 1 6: 0 7: 1000
IN 1: 1927 2: 2016 3: 62 4: 4506 5: 1 6: 2 7: 1000
IN 1: 1927 2: 2016 3: 62 4: 4506 5: 7 6: 1 7: 1000
IN 1: 1927 2: 2016 3: 62 4: 4506 5: 1 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 4506 5: 8 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 4506 5: 1 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 4506 5: 5 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 4506 5: 6 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 4500 5: 1 6: 0 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4500 5: 7 6: 2 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4500 5: 7 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4500 5: 1 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4487 5: 1 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4402 5: 7 6: 2 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 4221 5: 1 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 3903 5: 7 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 3410 5: 1 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 2768 5: 7 6: 2 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 2353 5: 1 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 62 4: 2159 5: 5 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 2055 5: 0 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 2003 5: 6 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 1984 5: 1 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 1971 5: 7 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 1964 5: 1 6: 3 7: 1000
IN 1: 1927 2: 2016 3: 63 4: 1958 5: 7 6: 1 7: 1000
IN 1: 1927 2: 2016 3: 63 4: 1958 5: 7 6: 2 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 1958 5: 0 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 1958 5: 7 6: 3 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 1951 5: 1 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 1951 5: 7 6: 3 7: 1000
IN 1: 1927 2: 2016 3: 62 4: 1958 5: 1 6: 1 7: 1000
IN 1: 1927 2: 2016 3: 62 4: 1958 5: 7 6: 3 7: 1000
IN 1: 1927 2: 2016 3: 63 4: 1951 5: 1 6: 1 7: 1000
IN 1: 1927 2: 2016 3: 63 4: 1951 5: 6 6: 2 7: 1000
IN 1: 1927 2: 2016 3: 63 4: 1951 5: 2 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 1951 5: 7 6: 2 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 1945 5: 1 6: 1 7: 1000
IN 1: 1921 2: 2016 3: 63 4: 1951 5: 6 6: 2 7: 1000
IN 1: 1927 2: 2016 3: 63 4: 1958 5: 0 6: 1 7: 1000
IN 1: 1927 2: 2016 3: 63 4: 1958 5: 8 6: 3 7: 1000
IN 1: 1927 2: 2016 3: 63 4: 1958 5: 1 6: 0 7: 1000
IN 1: 1927 2: 2016 3: 63 4: 1958 5: 1 6: 1 7: 1000
IN 1: 1927 2: 2016 3: 63 4: 1958 5: 7 6: 3 7: 1000
test]
test]
this it throttle down and then to the right then back to the middle
Permalink Reply by Rob. S on May 24, 2011 at 4:29am hey guys just loaded new code and everything is working fine now
it is a mystry problem i realli didnt like it at all.
ill keep posted to let u know if it plays up again
Permalink Reply by Al Ros on May 24, 2011 at 11:15am Hi
This has happened to me a couple of times and like you corrected when I reloaded the code. Not sure why it happens
Al
Don't know if it could be related to your problem but quite often after APM board reset, i loose channel 3 (throttle). So when it does occur, i can't arm motors and radio test show that ch3 does not receive anything. Testing the receiver output show that there is no problem on it.
Could be a hardware problem, at least on my board (APM 2560) or AVR fuse setting (fuse for start time ??).
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.676 members
1283 members
4 members
8 members
184 members
Powered by
