CE30Solid StateLiDAR Enabling Unimpeded Driving
Mechanical single channel LiDAR is pretty common in our life, but two problems cannot be neglected, i.e. short life span and high price due to the rotating measurement mode.
Benewake launches CE30, a solid-state LiDAR with large FoV. It could simultaneously output grey and depth information within 132° horizontal FoV and 9° vertical FoV. Meanwhile no mechanical rotating components exist internally, so higher reliability and stability could be ensured.
Based on the optimized obstacle avoidance mode, the region of interest (ROI) can be customized to focus on the obstacle information in the ROI and enable unimpeded driving. It can be applied in the general vehicle field, including Automated Guided Vehicle (AGV, such as intelligent warehouse vehicle), autopilot cars and industrial automation, etc.
Focus for Broad Space
FoV 132°x 9°, broader detecting region,
fresh rate 20Hz,
precise match of the application requirements in different scenarios.
Solid State for High Stability and Reliability
Solid-state design is adopted without any mechanical rotating components,
to guarantee the service life and enhance detecting stability and reliability;
compact structural design, embedded in the robot.
Two Modes for Flexibility
Two modes are available:
Point Cloud Mode focuses on 3D depth information;
Obstacle Avoidance Mode further processes
the point-cloud data to output the position
of the nearest obstacle.
MP Product
Cost effective. Global mass production ensures the quality and a stable supply.
“Eyes” of AGV
CE30 could be applied in the intelligent warehouse,
AGV, industrial automation, aided/unmanned driving,
etc. to address the need of obstacle avoidance,
mapping and navigation in intelligent unmanned equipment.
TE02
TF02Single Point Ranging LiDAR
New Generation: Farther and More Stable
TF02 is a newly developed product based on the widespread application
experience of TF01. It possesses a higher performance and is applicable to more
fields. On the basis of preserving multiple advantages from the last generation,
TF02 highly optimizes the energy system, product structure, fusion algorithm,
and shell material so as to achieve a 22-meter-long range and a more stable
ranging performance. Combining an innovative production process and multiple
software and hardware optimizations, Benewake upgrades LiDAR truly to a
consumer level and makes it applicable in numerous fields.
Remote, Accurate and Stable
The optimal range can be up to 22 m.
With the high frequency real-time measurement,
TF02 possesses impeccable data processing algorithms,
making product ranging perform more stably.
High Strength Body
An innovative production
process and hardware optimizations
make its water-proof level reach IP65.
The integrated structure
makes its body more powerful and
unbreakable, which highly
enhances its anti-corrosive quality
Fusion Algorithm and High Reliability
Based on the ToF (Time of Flight) principle, the product can work under 100k
Lux high light outdoors. In tandem with the original optical system design
and fusion algorithm, the product can resist disturbance from ambient light,
airflow, and electrons,resulting high data reliability.
Graphical Operation and Remote Upgrade
Concise upper computer operation interfaces integrate common functions,
such as data displaying, downloading, and Baud rate adjusting,
so as to make it more user-friendly.The new Bootloader function is convenient for
users to remotely upgrade product firmware online.
