Hey,
will Arducopter eventually support Coaxial setups, such as the Y6 or an X8?
Because i am planning on designing my own Coaxial-Copter running on the APM-Hardware.
Regards
Daniel
it's basically a mixer setting
so yes, it will support it
Hi Daniel,
You can do a coax X8 right now with the stock code if you use a 'Y' servo cable and 2 ESCs per arm.
I have though about this. This would be coaxial config (not counter coax)
Anyone proved this?
How about the efficiency?
What was I thinking about? Same motor spining at the same directionbut upside down will be counter coaxial so using a Y servo may work.
However you wil get 1:1 up down speed ratio which is not desirable for max efficiency but maybe you can stand with it or to compensate with different pitch props.
hi can some tell me the pro arrangement order for arducopter x8 with the present stock code
Hi,Im planning to build one too. Upgrading Quad to X8, any diagram pm me.TQ
it is not supported by stock code yet
Hi Daiel,
Have you made any progress?
Cheers,
Scotte
Yes, my Y6 is happily flying, as the ACM 2 Codes support y6 coaxial setup...
But how about the X8 quad coaxial configuration. Anyone have this running with the Ardupilot Mission Planner and hardware? If so can you please provide details of hardware and GSC setup?
Was this ever answered? Im also buildings X8 coaxial and want to know how to set up the GCS software or which others will work
