For a uni project a group of us are building a fixed wing plane and hooking up some IR cameras from the Nintendo Wii remote to find IR hotspots whilst flying.
We are using an Arduino Uno to control the IR cameras so that when a hotspot is found it will tell us. This code works and we are currently developing it to work for 3 IR cameras.When the camera has picked up a hotspot we would like to communicate this to the Pixhawk so that it can relay the coordinates of the hotspot back to our ground station (a laptop).
The problem we are having is getting the Arduino to communicate with the Pixhawk and the code which we would use to execute what has been said above.
Has anyone done this or a similar thing before and could suggest a way to go?
Thanks,
Ross K
Hi Ross,
I am looking into similar things for academic purposes. For a convention (http://smartgeometry.org/) we would like to connect some sensors, like temperature, humidity and thermal, to a pixhawk board and log the measured data along with all the normal flight data (gps, attitude, heading etc.)
Did you learn anything you'd like to share with us? I'm not committed to a pixhawk though. May also be APM or straight up arduino board.
Best regards!
I think this might be of help to you:
http://diydrones.com/forum/topics/incporating-sensor-data-into-the-...
Thanks James! Much appreciated
