I'm using an APM2 from the first batch and am, having some trouble with the compass/magnetometer enable setting. The board set has been flying and I'm just investigating the compass as prep to moving it to a quad.
I can check Planner's enable box for the compass and that changes MAG_ENABLE to "1". So, I write params to the APM2, then disconnect and reconnect Planner. After re-reading the params, MAG_ENABLE is still set to 1.
Now I power down the plane and reconnect the battery. Next, reconnect Planner and it reads the params. MAG_ENABLE is now "0", and Planner's compass checkbox is unchecked.
When I use the CLI it tells be that "Compass Initialization Failed!" for an HMC5883L device.
Is this an RTFM, a bug or a hardware fault?
Thanks.
Tags:
Permalink Reply by Florin on May 3, 2012 at 4:25pm I have exactly the same issue with mine. Let me know if you have found anything.
Now I'm trying to discuss this with support.
Permalink Reply by Florin on May 9, 2012 at 1:00pm Problem solved!!!
kind of stupid but my APM 2.0 board was mounted to close to the canopy magnets... (see the picture).
Permalink Reply by Andy Demartini on May 9, 2012 at 1:12pm Thanks for your update. I guess you replaced the magnets with velcro and that worked.
No one ever got back to me on this problem. In my case, the chip is bad. It's probably not repairable unless you have a SMT rework station available (and I do not). This chip is really more applicable to heli/quad use and I'm doing fixed wing. It's only advantage in fixed wing would be holding initial heading with auto-takeoff until the gps heading comes alive.
Still would have been classy to have "some" response from support.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.87 members
1288 members
125 members
39 members
4 members
Powered by
