compass not working !
Hello !
have just finished my new copter
but when I wanted to control the functions
I've always just north of the compass indicates noticed!
I've now changed the APM and the IMU board also the Compass
but always the same result!
also in the terminal all the parameters are zero !
I've done something wrong?
 or two compass modules are broken?
Peter
  • now I have the configuration done without compass
    Now I can see the data in the flight Diplay
    I hope that this problem is solved in the 40 version
    Peter
  • Hi Chris,
    I've loaded the code39b
    I mounted the Compass
    directly
    I will try tonight  the 38 code
    Peter
    What version of the code are you using? And how have you attached the compass?
