I'm getting these compile errors from the latest git version, as far as I know all the libraries are there so not sure why these errors would appear. Anyone with greater experience help me out?
In file included from ArduCopter.cpp:93:
GCS.h:129: error: 'ParamToken' in class 'AP_Param' does not name a type
ArduCopter.cpp: In function 'void update_trig()':
ArduCopter:1850: error: 'safe_sqrt' was not declared in this scope
ArduCopter.cpp: In member function 'void GCS_MAVLINK::handleMessage(mavlink_message_t*)':
GCS_Mavlink:1165: error: '_queued_parameter_token' was not declared in this scope
ArduCopter.cpp: In member function 'uint16_t GCS_MAVLINK::_count_parameters()':
GCS_Mavlink:1648: error: 'ParamToken' is not a member of 'AP_Param'
GCS_Mavlink:1648: error: expected `;' before 'token'
GCS_Mavlink:1650: error: 'token' was not declared in this scope
ArduCopter.cpp: In member function 'void GCS_MAVLINK::queued_param_send()':
GCS_Mavlink:1678: error: no matching function for call to 'AP_Param::copy_name(char [15], unsigned int, int)'
G:\My Documents\Arduino\libraries\FastSerial/../AP_Common/AP_Param.h:95: note: candidates are: void AP_Param::copy_name(char*, size_t)
GCS_Mavlink:1687: error: '_queued_parameter_token' was not declared in this scope
ArduCopter.cpp: In function 'void Log_Write_Performance()':
Log:650: error: 'class AP_DCM' has no member named 'renorm_range_count'
ArduCopter.cpp: In function 'void calc_loiter(int, int)':
navigation:150: error: 'class AC_PID' has no member named 'set_integrator'
navigation:151: error: 'class AC_PID' has no member named 'set_integrator'
ArduCopter.cpp: In function 'void calc_nav_rate(int)':
navigation:220: error: 'class AC_PID' has no member named 'set_integrator'
navigation:221: error: 'class AC_PID' has no member named 'set_integrator'
Getting different errors now, have made sure the libraries are in my sketchbook location.
Anyone?
ArduCopter:134: error: 'UBRR1H' was not declared in this scope
ArduCopter:134: error: 'UBRR1L' was not declared in this scope
ArduCopter:134: error: 'UCSR1A' was not declared in this scope
ArduCopter:134: error: 'UCSR1B' was not declared in this scope
ArduCopter:134: error: 'U2X1' was not declared in this scope
ArduCopter:134: error: 'RXEN1' was not declared in this scope
ArduCopter:134: error: 'TXEN1' was not declared in this scope
ArduCopter:134: error: 'RXCIE1' was not declared in this scope
ArduCopter:134: error: 'UDRIE1' was not declared in this scope
ArduCopter.cpp: In function 'void USART1_RX_vect()':
ArduCopter:134: error: 'UDR1' was not declared in this scope
ArduCopter.cpp: In function 'void USART1_UDRE_vect()':
ArduCopter.cpp: At global scope:
ArduCopter:135: error: 'UBRR3H' was not declared in this scope
ArduCopter:135: error: 'UBRR3L' was not declared in this scope
ArduCopter:135: error: 'UCSR3A' was not declared in this scope
ArduCopter:135: error: 'UCSR3B' was not declared in this scope
ArduCopter:135: error: 'U2X3' was not declared in this scope
ArduCopter:135: error: 'RXEN3' was not declared in this scope
ArduCopter:135: error: 'TXEN3' was not declared in this scope
ArduCopter:135: error: 'RXCIE3' was not declared in this scope
ArduCopter:135: error: 'UDRIE3' was not declared in this scope
ArduCopter.cpp: In function 'void USART3_RX_vect()':
ArduCopter:135: error: 'UDR3' was not declared in this scope
ArduCopter.cpp: In function 'void USART3_UDRE_vect()':
ArduCopter.cpp: In function 'void init_ardupilot()':
system:172: error: 'DDRL' was not declared in this scope
Bump...
check that the tab tools-> board has selected the correct board
Thanks Andrea, solved some of the errors but still getting these:
(Are the libraries updated from the git too?)
J:\APM\APMSource\ardupilot-mega\libraries\AP_Common\AP_Var.cpp:29: error: 'AP_Var' has not been declared
J:\APM\APMSource\ardupilot-mega\libraries\AP_Common\AP_Var.cpp:30: error: 'AP_Var' has not been declared
J:\APM\APMSource\ardupilot-mega\libraries\AP_Common\AP_Var.cpp:31: error: 'AP_Var' has not been declared
J:\APM\APMSource\ardupilot-mega\libraries\AP_Common\AP_Var.cpp:35: error: expected constructor, destructor, or type conversion before '*' token
J:\APM\APMSource\ardupilot-mega\libraries\AP_Common\AP_Var.cpp:36: error: expected constructor, destructor, or type conversion before '*' token
J:\APM\APMSource\ardupilot-mega\libraries\AP_Common\AP_Var.cpp:37: error: 'AP_Var' has not been declared
J:\APM\APMSource\ardupilot-mega\libraries\AP_Common\AP_Var.cpp:38: error: 'AP_Var' has not been declared
J:\APM\APMSource\ardupilot-mega\libraries\AP_Common\AP_Var.cpp:42: error: 'AP_Var' has not been declared
J:\APM\APMSource\ardupilot-mega\libraries\AP_Common\AP_Var.cpp:42: error: expected constructor, destructor, or type conversion before '(' token
I did a test, and also I have some mistakes,
until last night everything worked,
I believe there are errors in the updated files, maybethe version for the compilation of the 022 arduino?
Still looks like you have library issues. I just pulled and both AP and AC build without error from the latest master. I can also go back to the Arducopter-2.4 tag.
Note that the IDE is not very clever about noticing when files change, particularly when you roll back. Restarting the IDE helps a lot.
Seems only in "libraries\AP_Common\AP_Var.cpp", Phil can you attach that file here?
Graham,
That file appears to be deleted. It's not in my local clone repo or the main repo
http://code.google.com/p/ardupilot-mega/source/browse/#git%2Flibrar...
If it exists at that path on your computer then you are not up to date with Git.
There is a file of that name in the AP_Var directory. It was moved there with the comment
commit 451724e80d7ccc2cf9a7313a7248ededa8b31c6b
Author: Andrew Tridgell <tridge@samba.org>
Date:   Mon Feb 13 14:57:46 2012 +1100
    move AP_Var code and example into libraries/AP_Var
    you can use AP_Var by defining USE_AP_VAR
However, I don't that file is your answer. The EEPROM scheme was rewritten to save RAM and I suspect this file relates to the old way.  My build using the source from Git works as-is.
with the new update the compilation is ok
I do not know if it is compiled AP_var
Ok, it compiles, thank you! Had a few more errors but just deleted the offending .cpp files and it works. libraries/AP_Var had the updated files in italready
Think I copied some libraries over from an old installation.
Thanks again guys
Broken AGAIN after latest pull from Git...
ArduCopter.cpp:81:40: error: Filter.h: No such file or directory
ArduCopter.cpp:83:62: error: AverageFilter.h: No such file or directory
ArduCopter:301: error: 'ModeFilterInt16_Size5' does not name a type
ArduCopter:308: error: 'sonar_mode_filter' was not declared in this scope
ArduCopter:534: error: 'AverageFilterInt32_Size3' does not name a type
ArduCopter:535: error: 'AverageFilterInt32_Size3' does not name a type
ArduCopter.cpp: In function 'int16_t get_rate_roll(int32_t)':
Attitude:153: error: 'roll_rate_d_filter' was not declared in this scope
ArduCopter.cpp: In function 'int16_t get_rate_pitch(int32_t)':
Attitude:183: error: 'pitch_rate_d_filter' was not declared in this scope
ArduCopter.cpp: In function 'void init_motors_out()':
motors_quad:37: error: no matching function for call to 'APM_RC_APM1::SetFastOutputChannels(int, AP_Int16&)'
J:\APM\APMSource\ardupilot-mega\libraries\APM_RC/APM_RC_APM1.h:21: note: candidates are: virtual void APM_RC_APM1::SetFastOutputChannels(uint32_t)
You must be doing something wrong.  I just pulled and compiled, not problem.
Just to be sure (I was doing this wrong until last week), go into Arduino/File/Preferences.  Point the sketchbook location at your trunk clone directory.  Hit OK.  Then close Arduino and reopen it.  (that's the part that tripped me up!)  Then go File/Sketchbook and open Arducopter.  Try compiling.  Should work.
