First off.. I want to say this is an awesome application! I plan on adding
full telemetry and FPV to my drone. I have a few questions. I am running the latest arducopter firmware, mavlink 1.0 and mission planner 1.92. When I load a log file to graph I have a dialog box stating I can set the firmware version near the com port selection box. It's no where to be found I cant set it.
After I hit ok I get the error "Compile Failed". I click on OK and get the Graph This dialog window.
How do I set the firmware version ?
Tags:
Permalink Reply by Andrew Radford on June 19, 2012 at 1:10am I think this is a hangover from when you used to have to set the connection to 'Arducopter' vs 'Arduplane' mode manually. It is now detected from the heartbeat packets I believe. (There are slight differenced in how altitude is treated between the two).
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.58 members
1355 members
88 members
24 members
207 members
Powered by
