Crash after fordward on Altitude Hold
I´m desperated about this issue. My quadcopter has fall down 3 times about this issue.
My config is, Tarot 650 Sport
8000 mah 4S
Afro ESC 30a
Turnigy 4108 480kv
15x7.5 CF props
2,7 kg AUW
Controller and video with second baterry, 8000 mah only for esc and motors.
The crash vid.
https://youtu.be/u7mIxj63JDo
This happens when i go to full or mid throttle in Altitude Hold mode, then suddenly motors stops and the quadcopter drops as a brick.
I think this issue is related with the inclination parameter Angbst, shows big negative values on crash moment, and Throut values goes to 0 in this moment, but i dont know what is wrong.
Thanks,
2015-07-09 21-05-17.log
  • SOLVED!, Finaly it was a ESC sync failure. I've change all to Rotor X 40A and it works fine.
    I did a Autotune and works well.
    Thanks,
  • check for sync problems, took a very quick look at RCOUT , and the "motors" were not commended to stop.
    search forum for ESC sync problems, and do some serious testing for that.
    • Thanks,
      I´m thinking to change my esc to hobbywing xrotor 40a, many people says its work well with my motors.
      I will change all wiring for posible brownout (ground loop) and change esc.
      Waiting for china post, i will comment if this issue will solve.
      • Looking at your video - it also seems like there's a lot of vibration...   have you checked your vibration levels..?
        This can be the kiss of death for APM's..
        • 3702793861?profile=originalThink you might have a barometer issue..  Have you got the breathable foam over the barometer?
          Your log also shows several GPS glitches... which has no bearing here because you were in Altitude hold mode..but still...
          • I don't activated IMU log, i dont know if i have vibration, but in the video i see a lot of vibration at full forward, but i dont know if only is the gimbal or all,
            Baro and Gps glich was after chash. I have all the electronics separated from esc and motor battery with other battery.
            I used 4s for motors and esc, and 3s for rest all.
            In my new build y will put all with 4s battery and BECs.
            New ESC are shipped i waiting still for my new build.
            Thanks for the replies.
