1. Both: cruise throttle and airspeed can be set, but why?
If I set airspeed (TRIM_ARSPD_CM), then throttle cruise percentage(TRIM_THROTTLE) should be dependent conditionally from airspeed.
2. TRIM_ARSPD_CM, is it in cm/s or in m/s. I think m/s, but what is this: _CM?
Tags:
Permalink Reply by Mell on November 16, 2012 at 4:58am Mission Planner 1.2.20 says in Advanced parameter List that TRIM_ARSPD_CM -"Airspeed in cm/s to aim for when airspeed is enabled in auto mode"
I dont want to beleve that it is in centimetes!?
Permalink Reply by Leo Hogg on November 16, 2012 at 9:40am Quite agree, there are gaps in the info. I thought maybe the Trim throttle was for non ASI equipped aircraft. And what does the ‘air speed corresponding to max throttle FBW-B’ do? (standard parameters).
Im still not really sure what’s going on with throttle and speed. My setup flies much faster in FBW-B than it does in Auto. Shouldn’t it be the same? So many parameters that seem to overlap.
PS
Its defiantly M/S
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
