Not sure what happened here but it appears my pixhawk may be dead? I can't connect to it via USB, nothing happens. I've tried the reset button as well. I have a very short video and picture attached.
Any help would be greatly appreciated. Thanks!
I get a "corrupt file" when trying to view your video. My experience with connection failure has always been that Windows gets confused about the com port assignments - go into device manager and see if you can see the port there, and then choose it. Try unplugging the USB cable and plugging it back in if you don't see the port. And/or look for the port on the pulldown list in the upper right corner of Mission Planner . Com speed setting also needs to be correct, I think it's the 115,XXX one.
Also maybe test your USB cable, they do fail.
Hope that helps
