DEV Support: Purpose of Message Deferment
All- I know this is a specific question, but if anyone can help, it will be much appreciated.
First, what happens to the APM/ArduPlane when a Tx serial buffer is over-filled?
Second, what does message deferment accomplish/ why is it necessary for standard telemetry?
Third, what is the danger of sending to a serial port without using checks for buffer size and/or some message deferment process? Could it cause the APM to re-set and re-initialize?
  • Hi,
    Then you will start sending corrupted messages, which are useless and wasteful.
    With deferment, it will be remembered that a message was not sent. The job is queued for when there is enough buffer space to do it.
    It looks to me like it is safe against that. But will just send rubbish messages that are not useful if the buffer overflows.
    Regards
    Soren
