Hello,
I got to the point in my first quad arducopter build where it came time to load the code, exciting!
With everything connected, (including ESCs) I proceeded to power up the board via USB.
The dim LED struck me as kind of odd, but at this point I don't know that what i've just done is a no. So I make 1 attempt to load the code whith no success obviously. That's when I unplugged it.
Upon closer inspection the manual I found it rather casually mentioned here:
"3. Upload the ArduCopter firmware to the APM.
I connected the battery, made a minor correction to my sketch folder name/location and the code loaded fine.
now when I power on the quad the motors beep really fast and nudge just a little....
I calibrated the esc's according to the manual and tested each motor idividually for proper spin direction
Thanks,
Toby
Post script,
in kinderkram's build log, at the bottom (after you fry your outputs)
there is this warning
IMPORTANT WARNING!!!
When you plug in the USB make sure you don't have your ESCs and motors connected.
Otherwise you will blow your outputs!
you guys know the next question.
Why is this warning not in the ArduCopter manual?
Tags:
Permalink Reply by Joel on October 25, 2010 at 6:58pm
Permalink Reply by Toby Stein on October 25, 2010 at 11:22pm
Permalink Reply by Toby Stein on October 26, 2010 at 10:22am
Permalink Reply by SciFly on October 25, 2010 at 7:15pm
Permalink Reply by Michael Munson on October 25, 2010 at 9:36pm
Permalink Reply by Phoenix on October 26, 2010 at 10:15am
Permalink Reply by Dan Sibisan on October 26, 2010 at 9:49pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
1290 members
51 members
11 members
182 members
Powered by
