Discussion forum for UAVDevBoard, Sparkfun's 3-axis IMU-based autopilot board
This is the place to discuss the new open source IMU-based autopilot board by Bill Premerlani.
Will this unit be able to have multiple waypoints uploaded?
John,
The C source code that I have written so far is for a "come home" feature, so there is only one waypoint. My intent is that this platform is for do-it-yourselfers to extend the firmware for features that they want, such as multiple waypoints. This would not be hard to do, since you would not have to change any of the interrupt drivers that handle tasks like generating pulses for the servos or communicating with the GPS. All you would have to do is extend the navigation routine.
As far as loading the waypoints, you could do this prior to launch either through a PIC debugger, or by writing your own command interface that would communicate through the spare serial link on the board.
Bill Premerlani
hi, would this unit be able to takeoff and land autonomously? thanks in advance, john
Hi John,
This unit will takeoff and land autonomously. Take a look at the following recent postings:
Three autonomous flights of an EasyStar.
Three autonomous flights of a GentleLady sailplane.
Two autonomous flights of a Funjet, flying at 200 meters/second.
Best regards,
Bill
Thanks for sharing information!
Can we use LS2003X Gps module for this board (5Hz,38400baudrate)?
Off the top of my head I cannot give you a complete answer. I will tell you what I know right now and get back to you with a more definitive answer.
The self test software and the "gentleNav" navigation software that I wrote for the board were developed using and EM406A SiRFIII, available from SparkFun for $59.95. If you have one of those, you can plug it into the board running my firmware and everything will work fine. That would be my recommendation.
You also should be able to interface with any of the other SiRFIII GPS radios if they have the same connector as the EM406A.
The board has a spare UART, so you could also work out a way to connect to it, and modify the firmware to use the spare UART.
The firmware expects the GPS to be running at 4800 baud, but it would be a very simple matter to change it to a different baud rate, all you have to do is load a different constant into the baud rate generator register.
I must say I like the idea of a 5Hz refresh rate, so as soon as I have some time, I will take a closer look at the LS2003X and get back to you with a better answer.
Bill Premerlani
By the way, with the 3 gyros and 3 accelerometers on my revised board, you really don't need a 5 Hz GPS, 1 Hz will be just fine. In the spring I plan to write some firmware that will do aerobatics.
Gentlemen,
Congratulations !!!
What you have achieved here is incredible!
Sure, it's been done before... but not in civilian laboratories.
Back in the 1980's, I was tasked to build a 3 axis IMU from the existing Copperhead missiles' roll rate sensor.
The unit had a Coriolis effect rate sensor and an accelerometer for each axis. The mission was to provide data to a flight controller for an ejection seat system, controlling a gimbal mounted rocket motor for propulsion.
The unit was able to turn on and provide calibrated data within 140 mS. It had a maximum angular rate of 3000 degrees per second and an acceleration limit of > 2000 G. However, the unit was 4" cubed and weighed ~ 1.8 pounds. It consumed ~ 5 watts of electrical power!!!
We've come a long ways baby...
ROB
Robert, thanks for sharing that, which was fascinating. I can only guess at what it cost!
Hi. Nice and compact board with a nice processor.
I have checked out your test-code and I would like to use this board to test autonomous flight. You mention that you have written a come home feature. Does this mean that you have stabilization code that I could take a look at as well ?
UFO-MAN
The stabalization code is on the board's home page.
OK tnx. Just discovered the link at the upper part.
Those _.__. statements; are those macros that run inline assemly code?
Also, the __builtin_mulss statments; is that mapped to the specific DSP and wide accumulator hw architecture of the DspIC?
UFO-MAN
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.
© 2012   Created by Chris Anderson.
