DIY gradiometer for a UAV/drone based geophysical survey system
Hi all,
i am thinking about an affordable way to build/buy a gradiometer system, that is light enough, to attach it to a drone. like
http://www.barnardmicrosystems.com/L3_geological_survey.htm
but low budget. :)
a gradiometer uses two (or more) magnetometers, as far is i know. the big planes use
(http://www.picoenvirotec.com/environment/templates/tmp_environment/...)
Scintrex CS-3 seems to be a popular magnetometer for this. i found that the Scintrex
produces a lighter one, the CS-3L (1,8kg/3.96 lbs).
http://www.scintrexltd.com/magnetics.html
but maybe there is an inexpensive way to built a gradiometer?
an arduino based solution would be perfect. but i found none.
Maybe someone can help out here? Thank in advance!
regards, Joe :)
Tags: aeromagnetik, anomaly, detector, geomagnetic, geophysical, gradiometer, magnetic, scanner, survey, system
Hi Joe,
Have you had any luck since your post in April? Please email me if you'd like to discuss further,  sumpterdude@me.com
TKS,
Bob Chaplin
Hi Joe,
Affordable? The CS-VL's cost US$20k each, for a gradiometer set up you will need two of them.
