As always I like to modify my equipment and the experience gained in my
Another topic I decided to tune up my Turnigy http://fpvbrasil.com.br/forum/topics/diy-mod-radio-turnigy-9x.
To use the DL I had bought a radio Turnigy to be unique to Fpv well
could change the way you wanted.
I started the desmontanto DragonLink:
To loosen the hot glue that holds the module I used a hair dryer (careful not to burn your hands ...)
Open the Turnigy 9x
Cut the cap and Antenna Drill holes for the LED and the Bind button.
A bit of liquid electrical tape ...
New Bed for DL
O BackLight - Não vou mostra como instala pois existem milhões de tutoriais na Net.
support
Connector Cover
Ready to Close
Close to the check that no cable is holding the Sticks
I cut out of the box and I put my Turnigy 9x and MiniGround FatShark.
Olha o Bodinho...
Now comes the sad story ...
At home most of the test I performed was without the antenna and the dummy load on the DL. When I arrived on the field and went to take the test away I realized that the Quad stopped receiving commands and the LCD was fading. These symptoms only happened with the antenna already stuck with the Phantom Load radio behaved normally.
After getting PU% $% $ $% went home to analyze the problem. I was thinking I had ruined the TX and returned to the same original box and to my delight the problems are over.
So I decided to shield the DL with some aluminum foil which solved the problem of
PPM signal but the LCD still clear even with the original box. To work around this problem I have isolated the motherboard and the Turnigy LCD and Flat Cable with aluminum foil.
was very pleased with the results. After shielding the equipment had no more problems.
Tags: +, -, 9x, BackLight, DiY, DragonLink, Mod, Módulo, Rádio, Turnigy
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
720 members
1355 members
207 members
Powered by
