Hi all,
I'm looking for some expert direction on what path I should take.
I have the following gear:
I have basic skills and knowledge of electronics and Adruidno however I'm not good with the programming side of things however I can copy/paste sketches and tweak them using advice from the internet.
I want to replace the stock gyro that comes with this quaddy with one of the above options. I want to be able to have position and altitude hold mainly for AP. I do however also like the sound of the ArduPilot however I'm not sure how much 'programming' I'd be required to do to get it working.
I like the DJI Naza because it will just do it. However it is about $400 for the gyro/gps kit. I like the ArduPilot because it means I can start playing with autopilot and waypoints etc but I'm not wanting to delve into the code to achieve it.
If most of what I want to do can be done through GUI with ArduPilot then that's what I'll go with. If that's the case, can someone recommend me exactly what I need as I can see there are cut down version that might not have all the electronics I need etc.
I'm wanting a pre-built ArduPilot kit that I can just wire up configure and go.
Thanks in advance for all your assistance.
Tags:
You don't have to touch the code with APM--absolutely no programming required! It's a one-click firmware load with the Mission Planner. Totally GUI-driven; perhaps the easiest setup in the UAV market.
Everything you need is here.
Permalink Reply by Crasher on July 13, 2012 at 8:41pm
Permalink Reply by Andre on July 14, 2012 at 3:07pm
Permalink Reply by Ben Thomas on July 14, 2012 at 4:30pm Thanks for all your help everyone. I ended up going with the APM from what you've said. I like to tinker and want a little bit of flexibility. I'm fine with configuring and putting it all together it's just the code where I need some guidance but it looks like I won't really need to to much if any of that. If I do, I'll just drop by here for some help.
Thanks again.
I bought both since my apm took ages to ship. DJI is a good platform especially with the gps but i am pretty sure apm2 is by far better. I expirience smoother flight characteristics in stabilise mode. The alt Hold is super on the 2.7FW and with a litle throttle mixer on the yaw it's fantastic. You wil enjoy it. My DJI still in the box no interest on using it for now.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
12 members
249 members
183 members
693 members
Powered by
