I have a 3DR Robotics Iris+ and new to this. I have successfully flown missions using Droneplanner 2 but learned the hard way on my second mission that you have to delete the previous one.
So I do that by deleting each previous waypoint. Is there a better way to delete an old plan?
I believe that in DroidPlanner 2 if you hold down the delete (trashcan) icon it will then give you the option of clearing all the waypoints at once. It seems to leave a single waypoint which i then have to delete manually, but at least it's not necessary to do them one-by-one.
Thank you Evan. Just tried and that does it. Tried in new version Pilot and works there too.
I had an issue yesterday when connected to Pilot but not for auto flight. I was flying in Loiter mode for about a minute and the iris+ stopped responding to my transmitter and acted like it was in auto mode. I checked and switch in loiter position. Tried to RTL but no luck kept going and decesened until it crashed. Broke the battery door off and one arm. All four props damaged. Anyone else experience this? Not saying I didn't screw up, might have but really careful to check as I am a licensed pilot and know about preflight.
