DX7s throttle arm is down to the left not right?
Calibrated DX7s to BNF Pocket Drone. It passes the pre-arm checks but will not arm with throttle down and rudder right. I have to use throttle down and rudder left.
Not seen this with my BNF 3DR setup before, so seeing this with PD has me baffled. Does anyone have any suggestions?
Julian
  • I'm using a DX7s. Entered servo setup option but unable to save reverse rudder option? X8 - yes, took it apart last year. Good learning curve.
    • If you can't save the setting on the transmitter then reverse it on the RC calibration page in Mission Planner
      Have you checked that your PD turns in the correct direction when you move the transmitter stick, it might be reversed too.
      Follow the instructions in the wiki here
  • Reverse the rudder (yaw) channel on the transmitter using the reverse servo option for rudder usually channel 4.
    BTW did you get the motor changed on your X8.
